W212 S212 E Class Common Problems
As I’ve experienced the 212 now for a number of years, here’s a compiled list of common problems and a minor insight into them. Based upon my experience at an independent specialist + forums / Facebook. If you can add to the list, please comment and will happily add to it.
This list is quite big, but these are by no means bad cars. Some are generalised and could occur on any car but notes will help out with the 212 E-Class.
There are a few common ones, but most faults are normally due to poor servicing schedule and improper maintenance or just age and mileage.
OM651 (2.1 CDI 4-Cyl Diesel)
FaultSummary
Coolant pump failureWater pump bearing/seal failure causes coolant leaks and overheating.
Coolant visible around front of engine.
Low coolant level warning
Coolant thermostat failureCauses slow warm-up or overheat. Stuck open = poor MPG; stuck closed = overheating. On higher mileage engines have seen bits of the plastic housing break off and get wedged in the thermostat.
Overheating. Slow warm up. Occasionally EML light if triggers a fault.
Differential pressure sensor failureAffects DPF regen accuracy. Can trigger limp mode or excessive regens. Also check pipes going to DPF for splits. Advise removing and physically inspecting.
Limp mode. Engine light
Split intercooler / boost pipesCracked/split plastic or rubber hoses cause loss of turbo boost and associated boost faults. Advise removing and physically inspecting as have seen some pipes with splits that can only be seen when removed. Check for sources of oil contamination that leads to degradation of the rubber, externally and also check inlet system not breathing excessive amounts of oil.
Limp mode. Engine light. Hissing noises under load. Lack of power
Inlet manifold broken boltsHeat/corrosion breaks inlet manifold bolts, causing associated boost faults and symptoms.
This can be awkward to diagnose as only leaks boost under higher load.
Typically on earlier OM651 engines.
The bolts are built into the manifold and cannot be replaced on their own.
EGR cooler coolant leakInternally cracked cooler leaks coolant into EGR system.
White smoke and coolant loss. Low coolant level warning
Fuel filter housing coolant leakCommon. Fuel filter housing has coolant leak where it joins to cylinder head. See my post here
Coolant leaking around inlet manifold area. Low coolant level warning.
Oil cooler / filter housing external leakFilter housing & oil cooler are a combined unit. Caused by gasket or housing warp. On early models with mechanical power steering can be a pain to replace as not much room around it.
Oil visible near filter area and towards bellhousing on that side of engine
Oil cooler internal leakOil and coolant mix due to internal cooler failure. Have seen this quite a few times.
Milky fluid in expansion tank
Timing chain stretch / tensioner wearCommon. If left, can cause severe engine damage (cam timing jump).
Unlikely but may be worth checking that oil filter is not blocked and or oil sump strainer not blocked.
Rattle on cold starts
Inlet pressure sensors failureMisreads pressure → turbo boost issues or limp mode. Usually fixed by sensor replacement. There are a few pressure sensors at various points on the air intake path – be sure to get the right one.
Limp mode. Engine light. Lack of power
Air mass sensor failureVarious fault codes and associated engine light. Sensor contamination is typical. Make sure you complete the adaption process after the sensor is replaced. Use a genuine sensor. Ensure air filter is clean.
Injector blow-by (“black death”)Failed copper seals leak gases; tar buildup, injector chuffing noise, fuel smell. Do not leave this for long as the longer its left, the more its going to cost you.
Tar buildup around injectors and rocker cover. Chuffing noises. Diesel smell in cabin
High-pressure fuel pump failureCan cause no-start, poor performance. Associated low pressure fuel system faults. When pump breaks up can end up with metal swarf in fuel system. Perhaps not so much of a common problem but more lack of maintenance. (fuel filter replacement or cranking with no fuel to pump)
Limp mode. Engine light. Lack of power. Non start
Glow plug or control unit failurePoor cold starts or misfire. Control unit failure can affect multiple plugs.
Engine light / Glow light. Poor cold starting
Swirl flap motor failureReduced performance, Often needs intake manifold replacement.
Engine light. Poor performance
DPF clogging / poor regenerationFrom short trips (questionable) or sensor faults. Leads to excessive back pressure in exhaust. Check sensors working OK and pipes from sensor to exhaust OK.
Engine light. Limp mode
Crankshaft position sensor failureCrank-no-start or sudden stall. Often no fault codes logged and occurs when hot.
Adblue faultsTriggers limp mode or countdown to no start.
Typically NOX sensor related faults. May require replacement NOX sensor/s and software updates.
Much talk around software update causing performance issues.
OM642 (3.0 V6 CDI Diesel)
FaultSummary
Coolant thermostat failureWater pump bearing/seal failure causes coolant leaks and overheating.
Exhaust back pressure sensor failureMisleads ECU → incorrect EGR/regen behavior, reduced performance.
Where the sensor threads in, check that it is not clogged up with carbon internally – this will cause false readings as the pressure is not getting to the sensor.
Timing chain wear / stretchIf left, can cause severe engine damage (cam timing jump).
Less common than on OM651. Typically higher mileages.
Rattle on cold starts. Poor starting (continuously cranks)
Injector blow-byFailed copper seals leak gases; tar buildup, injector chuffing noise, fuel smell.]Do not leave this for long as the longer its left, the more its going to cost you.
Air intake pipe to turbo seals (red seals)Common. Seal failure (swelling from oil breathed in inlet system) allows boost leaks, oil seepage near turbo inlet. Oil can leak onto inlet shut off motor and cause failure.
Turbo boost pipe seal failure (green o-ring)Typically this seal goes hard. On some models you need to remove this pipe to replace the fuel filter and it leaks afterwards. Causes boost leaks and associated issues.
Air mass sensor failurePart of the Y pipe that connects air filters to turbo inlet. Typically a air temperature fault occurs which is built into the unit.
Oil cooler seals leakVery common. Seals shrink and leak engine oil into engine V area. Messy and labour-intensive repair.
Swirl flap motor or linkage failureIntake swirl flaps stuck or disconnected. Triggers various codes and reduced performance. Can be blanked off.
Engine light
Turbo actuator failure (electronic)Poor boost control, shuddering on acceleration when cold. Common in high-mileage OM642s.
Engine light. Limp Mode.
Glow plug control module failurePoor cold starts or misfire. Control unit failure can affect multiple plugs.
Typically NOX sensor related faults. May require replacement NOX sensors and software updates.
Petrol Engines (M271, M276, M278)
FaultSummary
M271 timing chain stretchChain wears prematurely, causing rattle and cam/crank sync errors.
Ignition coil failuresMisfires under load or cold. Easy fix but common issue.
Valve cover gasket oil leaksOil seepage around top of engine, common with age.
M276 crankcase ventilation failurePCV diaphragm fails, leading to vacuum leaks or oil consumption.
M278 turbo intercooler leaksLoss of boost or oil residue near intercooler.
Oil consumption on high-mileage M271/M276Due to piston ring or valve stem wear.
Spark plug fouling / misfiresCaused by short trips or aging coils. Triggers EML and rough idle.
Transmission (5G/7G-Tronic)
FaultSummary
Conductor plate / valve body faults ( 7 Speed)Failure of speed sensors on gearbox electrics plate.
Causes harsh shifting, limp mode.
Early units especially affected.
The gearbox control unit (aka TCU, VGS plate, conductor plate) is attached to the valve body inside the gearbox. It is coded to the car and if fitted with a new one, Mercedes exchange unit or a unit from another car it must be reprogrammed. (yes you can SCN code a 2nd hand one)
Various companies offer repair of these units if you take your one out (and therefore will not need to be reprogrammed)
Worth noting that there is a very early version of the 7 speed box that has a valve body that will be incompatible with later control units. Ive only ever come across this once, was a very early 212.
Leaking pilot bushing connector (5 Speed)Allows fluid into TCU & wiring loom — can cause transmission faults.
Torque converter shudderJuddering under light acceleration. Often misdiagnosed as engine issue.
If the torque converter has an issue it is possible there is an oil supply issue to it which may mean there is an issue with the gearbox.
Harsh or delayed gear shiftingValve body wear, solenoid issues, or adaptation errors.
Gearbox pan / cooler line leaksCommon with age or lack of servicing. Cheap non genuine gaskets normally fit poorly.
Putting the wrong gearbox oil inNot really a common problem, but something common to a degree that we saw in the workshop. Further details to follow.
General / Chassis / Electrical
Body & Interior
FaultSummary
Front seat base cover splittingStitching or material wears on outer bolsters and seat base.
Armrest cover wearCommon due to use. Often peels or cracks.
Steering wheel buttons wearRubber coating wears off, especially on high-use buttons.
Seat recognition pad faultPassenger seat pad failure causes airbag light and disables SRS.
COMAND controller faultsRotary-style controller in centre console becomes unresponsive or jumpy.
Instrument cluster pixelationEarly models suffer fading or dead pixels.
Door seam / wheel arch rustCommon behind rear doors or front arches. Cosmetic but persistent.
Water ingress in bootTail light seals or vents leak water into boot floor.
Heater blower motor failureFan stops blowing or only works intermittently.
Suspension / Steering / Chassis / Brakes
FaultSummary
Rear subframe corrosionUK & EU models most affected. Often fails MOT/inspection. Various reports of being replaced FOC at dealers. Little info from MB.
Airmatic suspension faultsIf equipped. Estate models have rear air suspension.
Air bags leak as they get older as would any rubber deteriorating. If left sat for a period of time this can make the situation worse.
If the struts are rising or there own, check; level sensor rods are connected to level sensors. Check air pressure relief valve on pump is working and wiring to it is not corroded.
Air line leaks from rubbing on chassis.
Compressors wear out if faults not rectified
Front control arm bush wearClunks or vague steering. Common around 70–100k.
Ball joint wearKnocking over bumps or vague handling. Check antiroll bar links and ball joints first.
Handbrake release handle Breaks off occasionally. Easily replaced.
Rear shock absorber mounts corrodingRear shock absorber top mounts corrode. Causes knocking noises. Not visible unless removed to check.
Electrical / Electronics
FaultSummary
Steering lock inoperativeELV module fails → no start, steering won’t unlock. Can be repaired. Coded to car.
Ignition switch failureKey won’t turn or no power. May need EIS module. Can be repaired. Coded to car.
Parking sensor (PTS) failureConstant beep or dead zones. Sensors corrode underneath paint. Occasionally wiring corroded inside bumper / plug.
Reverse camera failureBlurry or black screen. Common in facelift cars with NTG 4.5.
COMAND/NTG head unit failureFreezes or reboots
Headlight control module failure (ILS)Adaptive lighting failure or DTCs. Often water ingress due to crack in lens / lamp unit.
Alternator voltage regulator failureLow voltage, battery light,. Brushes / slip ring wear out around 300,000 miles. Can be replaced but requires dissasembling alternator
TPMS sensor failuresSensor battery dies or loses communication. Warning light for tyres. Normally at around 10 yrs old.
One thought on “W212 S212 E Class Common Problems”
