Mercedes Gearbox / Battery Reset – E Class W212/S212
Intro
Ive seen a lot of talk about doing a ‘gearbox reset’ or ‘battery reset’, normally amongst conversation regarding gearbox problems. Gearbox problems can be not changing gear, holding onto gear till high RPM, delayed engagement or harsh / erratic gear change. Occasionally people report issues after having a gearbox service.
But what does ‘gearbox reset’ or ‘battery reset’ actually mean and is there some truth to it?
As always focusing around the E Class W212/S212 generation, although the whole discussion dates back a while as we will discuss further on.
Mercedes transmissions adapt but not necessarily to how you drive. It uses multiple maps and tables to control the gearbox based on a load, pedal positions and driving resistance. Over time these tables ‘adapt’ the control of various oil pressure points in the gearbox. The end result is a smooth pull away and gear change.
All of this info has come from experience with dealing with these faults at a workshop + researching deeper into WIS/Xentry documents for this post. Happy to hear any different thoughts, please send me a message if so.
Spoiler alert:
There is no official Mercedes-Benz document that describes a “pedal reset” or “battery reset” for transmission adaptations. Mercedes does not publish it as a supported procedure. (and probably never will)
‘Ways of Resetting’
1: Pedal reset
Sit in the car, doors closed
  1. Turn key to Position II (ignition ON, engine OFF)
    Push-button start: press Start without brake
  2. Press the accelerator fully to the floor
  3. Hold for 20–30 seconds
  4. Release pedal
  5. Turn ignition OFF
  6. Wait 2–3 minutes
  7. Start the car normally and drive gently
2: Driving adaptation relearn
You can “reset” behavior by teaching it again. For the first 20–30 minutes of driving:
  • Use smooth throttle
  • Allow upshifts at low RPM
  • Avoid kickdown
  • Let the car come to full stops
  • Drive in both city and highway conditions
3: Battery disconnect (may help)
This may clear some learned values on older cars on certain control units.
  1. Disconnect negative battery terminal
  2. Wait 15–30 minutes
  3. Reconnect
  4. Drive gently for relearn
Where this info has come from (my view)
Long-time Mercedes specialists (especially pre-2015 era) probably observed that on some older TCMs, holding full throttle with ignition on could trigger a throttle/TCM reinitialisation.
For the battery reset side of things, in some WIS documentation Mercedes states that after battery disconnection, certain control units may lose volatile learned values & require reinitialisation / teach-in. And this is true, but depends on what year / gearbox you have.
These findings were shared internally, then spread to forums and repair communities
Across the forums and communities, some owners reported improved shifting, others reported no change. Success correlated mostly with older models & 5G-Tronic / early 7G-Tronic gearbox wise and cable throttle or early electronic throttle systems.
Mercedes does have legitimate procedures for, throttle actuator initialisation & ECU relearn after battery disconnect, on some older vehicles. Throttle reset indirectly affected shift feel and people assumed the transmission was being reset.
So the “gearbox reset” label stuck, even when it wasn’t truly resetting gearbox adaptations.
The battery reset may help you say? Well Depends on the gearbox
TLDR Answer
  • 722.6 is the only gearbox where Mercedes documentation clearly acknowledges that power loss can affect adaptation quality.
  • Early 722.9 sits in a gray area: WIS language allows for possible adaptation invalidation, but behavior is inconsistent.
  • Late 722.9 (7G‑Tronic Plus) adaptations are designed to survive battery disconnects, and Mercedes omits any power-loss teach‑in requirement.
  • Across all three, Mercedes officially supports only STAR/Xentry for controlled adaptation reset and teach‑in.
In more detail
722.6 (5G‑Tronic)Early 722.9 (7G‑Tronic)Late 722.9 / 7G‑Tronic Plus
Typical years in W212Up to ~2010 (market/engine dependent)~2008–2012~2014–2016
Control unit supplierBoschBosch (early variants)Continental (later variants)
Adaptations presentShift pressure, timing, basic wear compensationShift pressure, clutch fill, overlap, driver biasShift pressure, clutch fill, overlap, driver bias (expanded)
WIS mentions adaptations learned during drivingYesYesYes
WIS mentions power-loss effects on EGSExplicitImplicit / conditionalNot mentioned
WIS requires teach‑in after battery disconnectMentioned / impliedReferenced as possible lossNo
WIS requires teach‑in after control unit replacementYesYesYes
WIS requires teach‑in after transmission/valve body workYesYesYes
Adaptation memory storage typeMixed non‑volatile + volatileMixed non‑volatile + semi‑volatilePredominantly non‑volatile
Adaptations lost after battery disconnectPartialPartial / inconsistentNone (core values retained)
Sensitivity to undervoltageHighModerateLow
Observable change in shift feel after battery disconnectStrong, durableModerate, temporaryMinimal / none
Xentry/Star documents flag teach‑in after power lossSometimesSometimesNo
Pedal reset relevanceLow (not official)Very lowNone
Battery disconnect usefulnessCan influence behaviorSometimes influencesIneffective
Only true adaptation reset methodSTAR/XentrySTAR/XentrySTAR/Xentry
The Real Reset – STAR / Xentry diagnostic reset
The only true reset is done with:
  • Mercedes STAR/Xentry diagnostic tool
This can:
  • Clear transmission adaptations
Will it fix my problem?
If you are having issues and it’s keeping you up at night, disconnecting your battery at 2AM will probably help you get to sleep at 3AM as you will feel like you’ve done something to try and help it.
Honestly there is nothing to loose in trying any of the ‘resets’. But don’t hold out hope. If you’re lucky, what ever is causing the fault may have gone from an active fault to stored fault and it’s ok for a while.
Clearing the transmission adaptions with Star/Xentry may or may not improve the issue. Ultimately, it depends on the fault; engine related problems can cause gear change issues and mechanical gearbox problems will not be fixed by anything relating to software. On the other hand software is not 100% perfect and there could just be ‘an error in the matrix’.
The best route is to have it diagnosed by a specialist with Xentry that knows what they are doing. There’s probably a software update available for it to which, generally, is never a bad thing. Software gets refined over time and may well be an improved version.
If taking to someone to diagnose, give them all of the information you can;
  • Has anyone else done anything on it recently?
  • Do you know the history of the car?
  • Has the gearbox been serviced? (on time, with the right fluids, there’s different types depending on the box)
If its a genuine ‘since you done ‘X’ on my car, the gearbox is ‘Y’ then try to resolve it with the last person that touched it. If no result, give the next person all of the info.
These details may seem basic but can help in making a decision on the appropriate action.
Still stuck?
I will try to help, send me a message
